The first section is largely a copy and paste from an old build thread on a different forum (2012 or so).
Switching to 35s
Midarm install
Current work starts with the Atlas install and axle swap.
A little backstory, purchased the Jeep back in 2004, was a salvage rebuild.
Over the last 8 years, the Jeep has made it to this. Most of it is normal 33" build stuff.
Around a year ago I noticed a soft spot in the frame by the rear crossmember. Since the frame is already a little twisted, I figured it was best just to swap it out.
Purchased a frame from Davey's Jeeps. Not sure where it was from, but it has no rust. A little red dirt came out when I washed it the first time.
Plans are:
Swap frame
Raise body mounts 1.25"
Change shock mounting
Detroit in front
Poly Perf cage
Mastercraft seats
Savvy Under Armor if funds allow
Switching to 35s
Midarm install
Plans are:
Swap frame
Detroit in front
Poly Perf cage
Mastercraft seats
