Hey TJers,
I've started the process of swapping the input shaft on my NP231 from the stock 23-spline input shaft to a custom 31-spline input shaft that I bought from NorthWest Fab. I'm swapping input shafts so I can mate my NP231 to my Ford 6r80 6-speed automatic transmission, which has a 31-spline output, that I've installed behind my Kubota Turbo diesel in my TJ Wrangler.
The teardown of my NP231 has actually gone very well but I did notice some wear on the plastic for the shifter forks. Other than that, the rest of the internals of the transfer case appear to be in great shape.
After I got the 6-pin planetary removed from the NP231 housing, I did not that were was a shim with the original input shaft. At the time I didn't think much about it, but now I'm wondering if I don't have my input shaft shimmed correct which caused the wear on my shift forks.
If anyone has any information on where I can read up on the tolerances and shimming for the NP231 input shafts, that would be greatly appreciated!
Here is the video if you want to watch it:
Thanks
Grant
