Soooo...got all excited about this swap and started doing a little digging on line for engine specs, availability & etc. In the process, the wife called. During the conversation, I mentioned the swap you're doing. SHE got all excited. Crap. Now I have to do some math.
A couple of questions for you...
How noisy is that Kubota? The old school diesel rattle makes her nuts.
What, exactly, am I looking for when I search for a Kubota V2403? It appears the newer ones are electronic / common rail. Is that correct?
The Kubota swappers web site is pretty sparse, do you have additional resources to investigate? I'd be sticking with my manual transmission, so your point about engine position is a good one.
Still going through all of your videos...cool stuff!
Okay so a ton of information to go over here. In terms of noise I was surprised by how quiet the engine is. What's nice about these Kubota Engines is that they are 2000~2012 diesel injection technology. This really means one thing! The injection is MUCH more refined than the older diesels like a 4BT or an OM617. Here is a video of my V2403 engine test un-edited.
Also consider this engine is only like 414lbs vs the 4BT's massive 775lbs and the OM617 585lbs as well. That reduced massive is really going to help with noise and vibration from the diesel engine.
Truthfully I think this is about the same noise level as my Kobalt quiet series air compressor. Also it's SMOOTH! It doesn't look like it in that video, but that was the first time I got the V2403 to ever run, so it was getting the air bubbles and crap out of the injectors. If you watch the engine gets smoother the longer it runs. I wasn't running coolant or anything through it so I didn't want to run it that long!
I thought I had my GoPro running but in the only other run I did I REVed the V2403 a couple of times and it was smooth and quiet considering there is no exhaust or muffler on the engine at all! I honestly believe that once the engine has an exhaust with a diesel catalytic converter and muffler it's going to be VERY quiet.
Also I'm going with Brown Dog Offroad's super flexible rubber motor mounts for an XJ, which I know an XJ motor mounts work in my setup, which are suppose to really help with suppressing engine vibrations.
So the answer to your first question, because of the newer diesel technology, exhaust, cat, muffler, and super flexible rubber motor mounts there should be very minimal noise and vibration.
Okay onto the second question. If I were you I would be looking for a Kubota V2203 not the V2403. The V2203 are the most common engines, most of them came out of refer units when California changes it's emissions laws and I see them for sale all the time. Here is a generic eBay search:
Kubota V2203 eBay Search
There are two types of V2203 IDI and DI which stand for Indirect Injection and Direct Injection. The DI motor's will have about 15% more horsepower and torque compared to the IDI motors. Other than that they are the same. I wouldn't spend more than $1300 on an IDI and more than like $2000ish on a DI, but that is just me. I've seen them on craigslist and facebook for sale as well.
I honestly can't tell you about your manual transmission. I would imagine that 2" forward would not be terrible and at that distance it would be easy enough to just build another set of frame mounts on your TJ frame out of some metal. Running an AX-15 or NV3550 should be great, though I worry about the AX-5, I just don't think it can take the torque. Another thought it looking for another transmission you might want to run, a stronger one that is slightly longer because you can offset the length with where you want to mount the engine.
On the additional resources not really. I actually original got into the Kubota with a V1903 that I was going to be putting into my 1947 CJ-2A, I had gone with a completely different adapter and everything for that setup, but project is much more crazy that this one and now I'm getting a custom frame cut so I can weld it together that I decided to tackle my TJ Wrangler first.
I've being doing the research around this Kubota engine since March 2016 and I'm just now getting around to doing something with all of that research.
Let me know if you have any more questions!!! I'll do my best to answer!!!
Thanks
Grant
