The new engine is in and running smoothly. The gasket that came with the engine for where the camshaft positioning sensor/oil pump unit goes into the block is leaking.
It is just a thin paper gasket and forgot to put a thin layer of RTV on it to be safe.
I can find the sensor part that bolts on top but I can't find the unit or gasket that actually goes into the block.
Amazing how much oil can flow out of that sucker and yes the bolt is tightened down well.
Any advice on where to find that?
