Hello and Thank you in Advance,
I had the frame repaired on my 98 TJ from the top of the front wheel to the top of the back wheel on both sides. The shop that did the work told me there is now binding with the driveshaft and I should purchase and they will install a skid plate lowering kit. The jeep ran find until I tried to shift into 4Low. Stock IL6 motor, no idea what transfer case is in it, but I would suspect stock. The shifter sounds like it hits something metallic and will go into 4Low. My local jeep club said I should now raise the transmission so the linkage doesn't hit. Wouldn't think be counter-productive? The ground is still pretty cold and snow covered, but I'd like to purchase whatever I need so I can install once the weather clears up.
Any suggestions on what I need to do?
Rich
Rich
