For those interested in knowing how a York compressor dies, stay tuned.
This is perfect. I currently have 2 10” jl subs in a custom box that fits behind the rear seat. Dis this 10 years ago. Time to get the space back.To continue with added storage in the Jeep, I have liked some of the ammo can center consoles people have done. To continue with the audio improvements, I needed a place to hide a slightly larger sub that wouldn't impact what little space there is in a Wrangler.
This is how I made a ammo can center console with a sub enclosure. This will trouble a few audiophiles.
30mm Ammo Can Center Console with 8" Sub Enclosure
Plywood and masonite enclosure for a Polk dbdb840 8-Inch Subwoofer.
It goes in here.
And makes noise out of here.
The console fits here.
Lift struts and a light for the lid.
Fully installed.
The sub doesn't rattle and to my ears sounds perfectly fine.
The height of the ammo can is the perfect height for shifting. And the larger lid is far more comfortable arm rest than the factory console. Even with the sub, there is about 3-4 times more room inside the can.
I don't care for my cup holder. I'll make it better soon.
An oil level sight glass and an easy to access oil fill tube.
I just thought you had an air leak, was that an unrelated issue?
wow, that old ford looks like it was parked there last wk...........i don't think you could find a 1978 anything in the rust belt anywhere near that condition.
i KO'd my AC, was gonna leave it in for a mod like this later (maybe). the sys was emptied and i just cut and capped the hoses on top the engine for now.
would you think i need to put some oil down into it while it's dormant?
How has it been working/sounding 2 years later?Hopefully you are good with a table saw. The sub enclosure needs to be a snug fit inside the ammo can or else it will rattle and vibrate.
How has b
Where is the sight glass in relation to your ports? Will it be easy to glance at when everything is installed?Most of the parts are in. Hoping to install this weekend. Still waiting on a small transmission breather vent to go on top of the full tube.
Will you be able to keep the factory ac with the York?On a stock Jeep without a York, the glass would be on the passenger side of the alternator. It should be a fairly clear view to see if the bulb has oil in it.
