Quick question about your rear bumper: what's the measurement from the edge of the hitch receiver to the tub?
I don’t have an exogate but same issue with the bottom of the gate pushing out. I removed some snubber to where it still contacts the tire but doesn’t push the bottom out as much. But now I hear the gate rattle over bumps. Maybe I’ll rig something up like this after I do my frame raiseI'm thinking the spare tire support eliminated another small rattle.
As good as the Exogate is, it's biggest flaw is that is has only one attachment point on the driver's side. The factory latch. When the lower snubber is extended to stop the tire from bouncing, it is really easy to have the bottom of the gate get pushed out. And that still won't remove all of the movement.
With the just the support and no snubber, the gate sits flat in the body again. And there is no movement.
I will put the snubber back in soon after I get a shorter bolt and can play with the extension to get it just long enough without pushing the gate out.
It's a good idea. Mine is adjustable to account for tire wear, or a slightly different sized 35" tire in the future. It is ramped so that the tire slides up onto the support about 1/4". Enough so it barely sticks when I open the gate.I don’t have an exogate but same issue with the bottom of the gate pushing out. I removed some snubber to where it still contacts the tire but doesn’t push the bottom out as much. But now I hear the gate rattle over bumps. Maybe I’ll rig something up like this after I do my frame raise
That's the tightest measurement I've ever seen, with a receiver hitch. Functional and maintains an optimized departure angle. Nice work!No more than 2.5" from the tub.
Thank Blaine for the idea. On an LJ hitch can go flush with the bumper plate and the pin goes behind the crossmember.That's the tightest measurement I've ever seen, with a receiver hitch. Functional and maintains an optimized departure angle. Nice work!
What was the steering like with bad BJs?Ball joints! These lasted 67k miles. The driver's side lower was pretty floppy.
I think it was becoming a problem, which means they were worse than I realized. I'll know better tomorrow after more drive time.What was the steering like with bad BJs?
67k sounds great with the rep of them being a weak spot and what you've put those through.Ball joints! These lasted 67k miles. The driver's side lower was pretty floppy.
I traded Spicer for Spicer. The factory set I replaced lasted 100k, but those may have been in worse shape than these last set were in. I suspect I should start looking at replacing ball joints around 50k.67k sounds great with the rep of them being a weak spot and what you've put those through.
what'd you replace them with? my axle is reputed to be killin joints every 5k if i don't buy 600$ dynatracs.
Back to this. I was noticing a lot of corrections needed to go straight, a new intermittent shake, and the return of the pull to the driver's side. New ball joints took most of that away.What was the steering like with bad BJs?
Thanks for this. Ive been following this thread so keep us postedBack to this. I was noticing a lot of corrections needed to go straight, a new intermittent shake, and the return of the pull to the driver's side. New ball joints took most of that away.
Also, back when I put the big brakes on a couple months ago I saw that the BJs were showing their age.
Yesterday and today I often found myself at 80mph without realizing it.
I'm considering putting the Fox damper back in to see if it was doing what I thought it was doing. But first, I want to add a bit of caster.
The Fox is back in. The push is less now that the ball joints are new. Driving is absolutely better with the Fox. I still want to add a bit of caster in the hope that doing so will further diminish the push. Meaning that the jury is still out.Thanks for this. Ive been following this thread so keep us posted
And I got to try out the set of Coyote tire deflators I bought about a month ago.
https://www.coyoteents.com/product/coyote-automatic-tire-deflator-4-56-psi/
I think I like them more than the Currie Deflator. The Coyotes are slower. But I'm not spending that time crouched checking pressure. I asked for 8psi and after the short drive from the meeting place to the trail head, the psi on all four tires was within a half pound. I think I refine the psi setting to get closer to 8psi. Someday I'll take the time to do that.
