Somewhere in these first three months, after already having been thoroughly convinced that K&N is garbage and that most CAIs don't pull in cold air, I put in a real cold air intake that uses a paper filter. I built myself a Windstar cowl intake. This lowers intake temps from a pretty constant 190*F to between 5-60* above ambient air temperature, depending on ground speed and wind direction.
The hole into the cowl.
View attachment 34109 View attachment 34111
The horn of the air box inside the cowl.
Later on I wrapped the canister and tube in header tape. This reduced intake temps by 5*F.
Three years later, I will confidently tell you that there are little to no performance gains here. I have seen intake temps as low as 0*F and I still can't make the long steep highway climb up to the Eisenhower Tunnels any faster than stock. Eventually, I will make good use out of the extra room that removing the factory air box provides.
While we are on the topic, I also put in Bosch 4 port injectors. The only change I noticed was the smoother idle that many others have reported. Mrblaine once suggested that the smoother idle is really the result of having replaced worn o-rings which fixed a vacuum leak on one or more cylinders.
