Jackstands are the right way to do jobs like that. If you haven't already purchased them, make sure to get the taller 6 ton stands. 3 ton stands are strong enough but they're not tall enough for a Wrangler.
Yep add the gear lube when the Jeep is on the ground and level, just keep adding until it starts to overflow the fill hole.
You got this, enjoy getting your hands dirty!
