Do sPOD and ARB twin compressor mounts fit together?
ikeldsen
San Antonio
I just bought an sPOD switch for my 2000 TJ 4.0L (it is still being shipped) I also decided to buy the ARB twin air compressor. I’ve seen that the sPOD typically gets mounted right above the engine and the ARB compressor gets mounted right next to the engine above the intake manifold.
Does someone know if these two mounting locations will work together? If not does someone know of a better place to mount one of them?
For example this is the ARB mount that I was looking at: https://mountainoffroad.com/products/arb-air-compressor-mount-tj-99-06
Does your jeep have ABS? If not, you can just barely fit an ARB dual on the empty ABS tray. It’s a PITA to get it installed, but it takes up very little footprint once installed.
Reactions: Apparition
It does not have ABS but I am also installing metalcloak fenders which I believe gets rid of that tray.
I still have that tray with my Metalcloak fenders. Have a Viair compressor mounted there.
It's possible--> WTJF LINK
I initially followed that setup, but decided to move the compressor to the ABS tray.
I’m trying to find an installation guide/example to mount the compressor on the ABS tray but can’t find one. Does anyone know of a good one? I’m just trying to find out if I need to buy anything else so I can plan it out.
