10K rpm is hard to believe, that is 3 times faster than our balancer
https://www.superiordriveline.com/shaftsmaster/ will spin. It is also equivalent to the speeds at which a drive shaft would spin at around 250 MPH, generally speaking, depending on tire diameter and gear ratio. I wouldn't stand in the same room as a shaft spinning that fast. At any rate, if the vibration was there with the front shaft removed it is not the front shaft. So what else could it be? There is a guide to diagnosing some of the other possibilities here
https://4xshaft.com/blogs/faq/diagnosing-drive-shaft-vibrations?_pos=1&_sid=d6ec76a03&_ss=r. One of those possibilities is that we didn't balance the shaft well enough. If all the other things on the list seem to check out give us a call and we can arrange to get the shaft back for a re-balance. It's not a common thing but definitely don't beat your head against a wall with a bunch of other things if it seems like it might just be the shaft.
@Alatex
