Does this bump stop look normal?
Kenneth G Zinis
Bethlehem, PA
Guy, does this look like a normal set up with 4" lift, bumpers and spacers look correct? Thanks
Looks similar to my 4" setup at a glance. What makes you question it?
You don’t add bump stop from the top, you add it from the bottom, attached to the lower spring perch.
I don’t want to derail the thread, but how much do bump stops like this compress? I’ve seen my stock size down to the bump stop cup, but certainly these long rubber pieces don’t go that far? I’ve seen these a lot but mine already kiss the coils at full droop so I haven’t considered them for my use.
I’ll contribute to the OP by saying the space between pad and rubber looks a little bigger than my 4”, and I have about 5.5” from metal to metal (puck to bumpstop cup), limiting factor being tires.
Reactions: Kenneth G Zinis
