@badlieutenant Thanks so much, this radio is fantastic! Exactly what I was looking for!
As it's a slightly different model than was originally posted, I'll give a quick review of my experience. Bought this unit on Ebay, shipping only took 4 days and the item was well packed.
Install was about as easy as changing a light-bulb. All the cables and harnesses were keyed so you could close your eyes and get that connected up. Trim pieces pop right off, and there's a total of 6 screws and one (10mm) nut.
Sound- There was an immediate, noticeable improvement in sound quality and volume, even though I'm using the factory speakers.
Bluetooth hooked up to my iPhone 7 right away, can make calls, sync contacts, play music.
WIFI lets you use your phone as a hotspot while you travel. This works for google maps, youtube, or other mobile apps. Also, at a minimum you can connect to your home WIFI so you can download apps.
OBD2- Speaking of apps, I got an app called Car Scanner ELM OBD2 from the Play store, and it has all sorts of telemetry if you have a OBD 2 scanner. I have one called FIXD and it works fine. There's a paid version with more features.
Radio works great and is very easy to program. Also, has labels and music info as you'd expect.
Navigation works great if you want to use your hotspot from your phone and Google Maps or map app of your choice. It also comes with a GPS antenna and I believe you need an additional 3G or 4G service module to use that.
Backup Camera- I have the backup cam option, but opted not to connect it right now. Wiring looks straight forward enough but there are two caveats: First, you need a decent place to mount the camera. Most people seem to pull it through the center of the spare tire carrier. Since I'm planning on 33's and lift, this rear tire carrier will change. Secondly, you have to get 12V wire, most likely from your reverse lights, and I didn't want to tap into that until I get the rest sorted.
SD card- I grabbed a 64GB micro SD card and loaded it up with music and movies (it'll display pictures too). It also thankfully remembers where you left off when you stop.
Customization- They wisely let you personalize a lot of features. For example it comes loaded with images for most major auto makes so you can really give this a factory feel, or you can load your own graphic if you want. You can set the backlighting to any color you want. You can change some features of the main menus and things to make this very user friendly.
More- It has more features like outputs for audio and video for back seat screens, USB connection, DVR capabilities, and more. I haven't tried any of these yet, not sure I'll need them.
Lastly, the fit and finish of this is top notch. Knobs and buttons feel good and it fits perfectly into the factory shape.
I couldn't be more thrilled with this unit, especially for the price. Seller seems to have good support too.
