dropping axle to full bump
Eddie Greenlee
Mississippi
I posted this question earlier and have not been able to find it, so here goes again.
can you explain how to drop my axles to full droop so i can jack each side of my front axle up and make sure my bump stops, brake lines, shocks are properly set?
I just bought a 3 ton floor jack and I have two jack stands.
thanks !!!!
man that is detailed, I need a little more indepth instruction on the how toos of < jack up the sides of he frame and put jack stands under the front frame. Ill probably just use jack stands on the front first then do the rear. ill see if there is a video on youtube.
