99black Member Original poster Joined May 15, 2019 Messages 58 Location WV Feb 2, 2025 #1 If the voltage’s and the grounds are good. But the negative for the shut down relay is not there does that mean the ECM is bad.
jjvw AI Moderator Staff Member Supporting Member Ride of the Month Winner Joined Feb 17, 2018 Messages 31,015 Location Colorado, USA Feb 2, 2025 #2 More likely, it means there is a problem with an engine sensor that is triggering the auto shut down relay. What is the last thing you did to the engine?
99black Member Original poster Joined May 15, 2019 Messages 58 Location WV Feb 2, 2025 #3 Haven’t done anything to engine for long time. It cranks fine fuel pump works. But now spark. One of the main things I fined there is no negative from the ECM that controls the shut down relay. Also there are now codes.
jjvw AI Moderator Staff Member Supporting Member Ride of the Month Winner Joined Feb 17, 2018 Messages 31,015 Location Colorado, USA Feb 2, 2025 #4 Codes? Maybe those are related.
99black Member Original poster Joined May 15, 2019 Messages 58 Location WV Feb 2, 2025 #5 Yes I would say they are. But where would suggest one might start checking first.
jjvw AI Moderator Staff Member Supporting Member Ride of the Month Winner Joined Feb 17, 2018 Messages 31,015 Location Colorado, USA Feb 2, 2025 #6 99black said: Yes I would say they are. But where would suggest one might start checking first. Click to expand... Start by reading the codes either through the OBDII or through the ignition key method.
99black Member Original poster Joined May 15, 2019 Messages 58 Location WV Feb 2, 2025 #7 There are no codes show either way.
jjvw AI Moderator Staff Member Supporting Member Ride of the Month Winner Joined Feb 17, 2018 Messages 31,015 Location Colorado, USA Feb 2, 2025 #8 99black said: There are no codes show either way. Click to expand... But you said there are codes now. 99black said: .... Also there are now codes. Click to expand...
99black Member Original poster Joined May 15, 2019 Messages 58 Location WV Feb 2, 2025 #9 Miss spelling
99black Member Original poster Joined May 15, 2019 Messages 58 Location WV Feb 2, 2025 #10 That was supposed to be also there are no codes. Sorry about that!
