Looking to upgrade rear axel shafts. 2004 Rubi, geared to 5.13, stock F&R lockers, on 35's. If I've read correctly, splines need to match lockers and spider gears? Stock rubicon is 30 spline, so if I have stock lockers is it safe to assume the shafts that are in are currently 30 spline? I'm 2nd owner, PO did a lot of work but shaft upgrades weren't mentioned. Are there any other wearable parts I should be changing while I'm in there? Watched HorseJockys video, seems like a straight forward project? Says "smaller parts must be purchased separately", what else do I need? Revolution keeps coming up as the recommendation & comes with bearings already pressed. Anything else I need to know?
https://www.revolutiongear.com/prod..._brake_4140_chrom_moly_rear_axle_kit_87_06_tj
