Fender flare paint job turning to sh*t
This is important. My first thought was to paint any new set i got. To protect the original material from fading. But maybe for 160 bucks its easier and cheaper in the long run to just replace them.
And a decent used set can be had for even less.
Don’t get Crown, get the OMIX, which is the same as Rugged Ridge. They come with new stainless hardware. The fit is good and they look fantastic.
https://www.amazon.com/dp/B000FQ7CQO/?tag=wranglerorg-20
These are the new ones on my sons rig!
View attachment 258235View attachment 258236View attachment 258237View attachment 258238
Great looking TJ. Some people refuse to believe Omix/Rugged Ridge make anything decent other than phone cases. I have the same flares and they are pretty much identical to stock. They also seem darker than when I bought my Jeep new but that might be due to how quickly the originals faded.
Reactions: JMT
I’m telling you,the guys at the tire shops are not what they used to be This is obvious lack of pride by the installer, I personally explain these obvious things whenever I allow another human to work on my vehicle
I had a shop use the adhesive stick on weights on one of my Jeeps. They fell off 30 minutes later in my driveway. I got a refund and went somewhere else.:(
The wheel balancing weights should be on the inside so they're not visible. :)
Yeah, this rig is under construction. 😅 I hate that they do that. On steel wheels it compromises the paint too, and now there’s some rust.
Reactions: Weasellee
They didn't have that option on my current wheels. The bolts confused them. :)
p.s. I listed these wheels on Craigslist for $300 (5) and have had a lot of people wanting them. Not even a scuff in 4 years. I think they go for $120 each plus center caps now. I'm thinking of going to the Mammoth Boulder charcoal 8" wide wheels. I had them on my white Sahara. Still undecided.
Reactions: JMT
What are those? They look like d-windows with a sort of bead lock edge
CRAGAR Series 352 Street Lock D Window​
Simulated beadlocks. The inner edge will rip your sponge every time on the bolts when trying to wash them. I had them on two previous Jeeps.
Reactions: JMT
I like both those wheels. I’ll take the black steelies for f you can deliver to my son in Norfolk 😁
My Alloy wheels are stuffed from the weights being put on the outside, PO must have had them re balanced at some time with lots of weights :( I didn't notice until I had new tires fitted but there are now a lot of weight marks left behind that wont polish out.
  • Sad
Reactions: JMT
My flares are all oxidized and look like total crap. I do NOT want to paint them because I WILL screw it up. Over the years I have tried countless products to get that oxidation off and nothing works. Any suggestions from the masters?
Mine looked worse. Believe it or not. They were a blue color. The PO had obviously left my Jeep out in the socal sun for a long time. Everything was toast that was plastic.
My vote is cut your losses. And just buy new ones. Thats what I'm doing.
I mean no harm in trying the krylon. But then there is the task of taking them off and putting them back on. Twice of it doesn't work.
Or you could pick up a used set in not quite so toasted condition. ;) And paint them.
Your best bet is to look for a set of 4 1/4" Painted Sahara flares if you don't like fade.
Reactions: DarkStar357
