@hosejockey61 @macleanflood @anyone-who-knows...
Looks like I'm OK - The rotational torque spec - according to the manual - is 15 to 30 in-lbs for new bearings. I'm at 24. I was confused as some sources state 12-15, but as this is the FSM, unless someone knows of an error, I'm golden. It just felt awfully stiff to me, but numbers don't lie.
From someone who doesn't own a way to measure rotational torque , I believe this is just fine . As the relationship between theory and reality collide , one must ask the question , ( Do you install spark plugs only using a cal lab inspected and certified torque wrench following the MFG. factory spec . ) ?
In my opinion , given the range you stated and value you measured , you are just fine to finish this axle rebuild !
Yea, I'm just wanting confirmation that I'm using the right numbers - I can get confused pretty easily.
While the FSM states 20-40, you risk burning up your bearings as that number gets higher. A gear shop owner is the one who tuned me up on that. Great guy and an absolute wealth of knowledge. With that being said, you'll be fine at 24, been there done that. If it was much higher I would tell you to reconsider.
Whew! The way I was reading it was the Dana 30 was 15-30, Dana 44 was 20-40. Either way, its a relief and I appreciate the confirmation! So now I can throw the diff back in, get the axle shafts put in, then run my first pattern.
Ricky hit it...no pattern needed since it was just bearings. But we'd be curious to see....
roll the pinion to get a pattern.
I have read that the coast side is important with used gears.
So does this mean I should do it twice - once in each direction?
Check out the BFH garage videos on YouTube.
You can turn it by hand too. The drill just makes it quick and lots of reps. I wouldn't go out and buy tools to do that.
