1/8 turn, or inch? Turn would equal to roughly about 4 inches…Has about a 1/8 turn on slop in the steering wheel (steering box probably). Alignment shop suggested some of it could be coming from steering box.
Don't you have the same issue? Maybe you can work together on this.What is the backspacing in your wheels? If you're running something really low like 3", especially combined with wide tires like 12.5", your excessive scrub radius will make the rig follow ruts and grooves in the road and can feel darty.
Okay, I guess yours is slightly different, like a different color green.Maybe. Reading his description doesn't really resonate for me though. Mine is consistent and predictable (I would never use the word "dart" to describe mine) and mine requires constant left input to avoid pulling right, which is the opposite of his.
It's a lot. I uploaded a short to YouTube so I could share here.1/8 turn, or inch? Turn would equal to roughly about 4 inches…
I've got JL wheels with 1.25" adapters. No rubbing with this 285/70/17 tires.What is the backspacing in your wheels? If you're running something really low like 3", especially combined with wide tires like 12.5", your excessive scrub radius will make the rig follow ruts and grooves in the road and can feel darty.
I could rephrase, more of a distinct path change to the left. Not so much a dart but if you let go of the wheel on a flat road it's going left.Maybe. Reading his description doesn't really resonate for me though. Mine is consistent and predictable (I would never use the word "dart" to describe mine) and mine requires constant left input to avoid pulling right, which is the opposite of his.
If it's a leftward crowned road, try to keep it out of the ditch. If it's a right crown it'll stay straight for the most part but every now and then it will follow the crown no matter what.What does it do on a road that isn't flat? Like if it's pitched down to the right or the left?
How do you adjust camber on a TJ? I know it's possible but not necessarily an easy thing to do and a tiny bit isn't often suggested. Just wondering if you have a trick up your sleeve?Very little tiny bit of extra negative camber on the right side is a trick I used to do since Florida has sever road crown.
I’m new to TJ’s so I’m not going to sit here and BS. Other solid axle front ends we would get inserts that have off center holes for the upper ball joints. I was just reading the print out as my experience would decipher how it may make the vehicle drive.How do you adjust camber on a TJ? I know it's possible but not necessarily an easy thing to do and a tiny bit isn't often suggested. Just wondering if you have a trick up your sleeve?
Tires may need to be balanced. They are 3k miles old take offs from a Gladiator. My camber isn't necessarily out on the front because it is only .1 degree out of spec. The rear however could be a tweaked axle tube.I’m new to TJ’s so I’m not going to sit here and BS. Other solid axle front ends we would get inserts that have off center holes for the upper ball joints. I was just reading the print out as my experience would decipher how it may make the vehicle drive.
Edit: I don’t recall if anyone asked why his camber was out. (Worn upper ball joint, bad wheel bearing etc)…or is this normal for Jeep’s <-question I have because I’m new to them.
I genuinely think he needs to rule out the tires with a simple rotation before he continues to hunt down alignment issues.
I'm pretty sure the tires are not the issue, but I will check anyways. It did it with my old tires too.You’re .1 out of spec but you’re .7 different between left and right. “In Spec” is not the be all tell all for alignments.
Now is it out enough to justify the head ache and money to fix it, probably not.
Swapping the front tires and shaking down the front end is a free and 20min procedure that could out rule potential causes of your drivability complaint.
The steering gear box was loose, I tightened it and have yet to drive it much. I may have tightened it too much so I will do some more adjustingHave you checked for loose box?
