This thread was linked from another discussion around heater cores, so I wanted to add my experience with the Brassworks in our ‘05.
Installed but there was little to no heat output — at 210F operating temp best we got was 103F at the vents.
Pulled it because I figured there was an install error. Went to rinse the coolant out of it and figured out there is a complete bypass in the upper tank — as in, water flows into one neck on the tank, then immediately out the other. No coolant is actually being pushed through the core.
Returned it under warranty and it was sent back repainted — but in no way repaired. Bypass still there.
Reinstalled it and still had no heat output. Found a NOS Mopar from a guy who had one sitting on a shelf. Pulled it again and the Brassworks was covered in dried coolant — it was leaking.
Tried to get a refund under warranty — now getting ghosted by the owner.
Avoid at all costs. All the reviews suggest this is a defective design that won’t actually output any heat. I’m here to say they’ll also leak.
