Hey all -
New question. I'm sourcing a set of OE lower control arms. I have two options:
I'm leaning towards #1 just due to cost. My question is, how much life should I expect from the OE bushings? Typically speaking, should I be looking to replace them around 90k-100k regardless or do they last longer than that?
- Buy a used set with 85k miles on 'em for $20
- Buy a whole new Crown set for $200
My TJ has 175K on it and I replaced my OE with Crowns. They worked fine, but I only ran them for a few months before I replaced them with a Currie lift. I don't know the longevity of them, but they still look brand new so far of course. So what I am trying to say is if you want the OE, I would go with the Crowns even if they last half the time, it is still a good deal in my mind.
If you know you are going to replace them later, and are just trying to get by, you can probably be fine with the 20 dollar ones, but personally if you were going to put them on as replacements, I would go for the Crowns.
Any reason I should chose ACDELCO vs. Moog vs. Crown? Leaning towards ACDELCO mostly for the lifetime warranty (as opposed to Crown's 1 year). I can't imagine quality varies that much from brand-to-brand.
I've read some folks claiming the aftermarket OE brands use thinner material or substandard bushings vs. Mopar and some are better than others. If that's the case, would any of those brands be a safe bet?
Buying Mopar is out of the question. If I was shelling out $70/arm, I'd just cough up the extra $$$ for Currie at that point.
MML and BL installed this weekend. Big ups to @Chris for the hookup on the JKS BL!
MML job wasn't as bad as everyone made it out to be. I did run into a few snags. One of which was cross threading the M10 bolt on the driver side. I was so careful to start with just my fingers before cranking it. Must have caught one of the threads just right.
Good news is I was able to cut new threads using the old OE bolt and motor oil. Could have been a lot worse. For a second I was freaking out...
Thanks AC! I've actually decided to forgo the rear track bar bracket and deal with the slightly off-center axle until I buy an adjustable rear.Hey I have a JKS rear trackbar bracket, if you are still looking for one.
Shouldn't be an issue. With the control arm bolts correctly torqued, the mount ought to be clamped hard onto the bushing anyway.
Ran into something interesting today during the install.
After removing the Fabtech tubular LCA's, I noticed the bushing sleeve on the OE replacement was a hair too wide frame side to slide up into the bracket.
Upon closer inspection, it looks like the Fabtech LCA's have the same width bushing sleeve both frame and axle side where as the OE replacements have a 4-5mm wider sleeve frame side. When the Fabtechs were cranked to spec, it appeared to have pinched the frame bracket a tad too narrow.
No worries. I broke out the BFH and beat the frame mounts into submission. Still a pain in the ass.
Has anyone heard of this before?
Before I ask my next question, just wanted to thank the community for being so helpful. Absolutely love this!
Today I removed the dropped pitman arm and replaced it with an OE equivalent. I used a 15" crescent to seat the new arm. I applied a hair of grease on the splines before doing so. My method was crank really hard, tap with a 3lb sledge, back off the bolt, and then crank again. I kept this up until I could not get the wrench to move anymore. I put every ounce of strength I had into cranking this thing!
I'm confident it isn't going anywhere, but I'm a little discouraged I could not get the arm to seat as high up as the old one. Is this thing good to go?
