Boog nailed it. As I was reading this I was thinking the PO likely had a higher lift at first. No reason to install at dropped PA and TB bracket at 2 1/2” of lift (or any other time for that matter).That would explain your problem if that is correct. That old style RC track bar with drop bracket and dpa is for their 4-6" lift. Maybe the PO switched to their 2.5" springs and used the same track bar. I bought a Jeep with that setup on it and removed it ASAP. The Jeep was all over the road and dangerous to drive.
p.s. The shop shouldn't have to guess at the lift height. Stock springs measure 12" front/8" rear.
Thank you @OldBuzzard !Adjusting the toe:
https://wranglertjforum.com/threads/how-to-align-your-jeep-wrangler-tj.85
Page 1 shows you how to do it, but be sure to read pages 16 and 17 where there is an improvement on the method, and on the actual measurement.
Thanks again! @GollywomperI would go with a option that has a Johnny joint at both ends.
you can reply to a post then hit the "reply" button on the next so you can link multiple together all in 1 post.Also, newbie question, should I respond in one post to all replies? Or reply to each post individually?
Respond...Thank you @OldBuzzard !
....Got it thanks! @Gollywomper
