I’m not looking forward to the day it’s time to replace my Dssv shocks on the ZR2.
Be careful towing with that colorado mike....
Buy a Ford! Thankfully Fords have replaceable parts. (Mainly because it's not awesome from the factory lol).
Wow....This is my typical set-up when I tow the the Jeep. Been looking for a weight distribution hitch for it.
I didn’t know a Colorado would be up to towing a jeep. How’s it do? What’s the tow capacity?
Its pretty decent. Plenty of power and brakes. Little bit soft on the rear springs (which is why I'd like a WD setup). Trans and Coolant stay at normal temps, fuel milage goes to shit (but then again, they all do). The Z71 and other colorados actually have a 7200 lb tow rating. My ZR2 is derated a little (to 5K), but I figure the Jeep and trailer is probably right around 5500 lbs. My axle ratings are WAY higher than the overall tow rating, and the powertrain is the same as a "regular" Colorado (aside from the radiator they made shorter to improve approach angle). Its a pretty stress free experience. Its not a Full Size diesel, but it aint bad.
Have you towed it in any mountains?
Just the Appalachians. On one hand, I don't know that I'd want to tow over eisenhower with it...but on the other, I also think it would do fine and be able maintain 45 mph. I've never driven over the rockies though, so I don't really know.
One of the reasons I now have an engine brake.
The Rockies are a whole different animal. Be interesting to see how it did but I wouldn’t want to try it.
Plus coming down is pretty important too. One of the reasons I now have an engine brake.
You probably told me about them and I may have forgotten. But looked it up and that stuff is quite interesting.
https://www.motortrend.com/how-to/1...-shocks-explained-inside-the-multimatic-dssv/
This highlighted bit in the article is not clear to me .. you know more, Mike?
Special thanks to @gbirk and @rasband I have a hidden compartment for smuggling fuses across the border!
Link to the 3D files: https://www.printables.com/model/530385-jeep-tj-spare-fuse-bin-for-under-hood-fuse-box
How are you? How’s the jeep? Been a while and this is such a good build I’m dying to hear an update if you’re still around.
If you follow his YouTube channel, he has posted twice in the past year that he is currently doing chemo
Did not know he had a YouTube or chemo. Man that’s tough.
