How does this gear pattern look?
someguysjeep
simple guy
Lifetime Supporting Member
ohio
ok as mentioned in my build thread ( that not very everyone reads so hopefully this will have a larger response).
the pinion pre-load is 30 inch lb's, spec is 22-35.
the backlash is .008. spec is .006-010.
it looks pretty close to me. i must admit it could be just a hair more center tooth, but i don't think have the shims to move that little. last 2 shims available are .105 & .150
b4 i move anything what yall think?
Reactions: J R and Blondie70
so the more i look at it, the hit is just a tad high on the tooth. for this i believe i should increase the pinion shim some.
i've used the Billavista gear bible to help. and i went back and read it 4x and i did apply pressure to the gear when spun but they suggest 50# of resistance............i don't think i produced that, so i'll clean it all up and repaint it and try to get significant pressure b4 i run another test.
but i do have more space below the patch than above, so i'm kinda leaning toward just a bit deeper on the tooth .
i'll apply more pressure see what that yields and go from there.
alright, i wiped all that thick grease away. mixed a batch with a few drops of gear oil and jammed a couple wooden handles into the casing to force some load, this time i needed a ratchet to turn the pinion.
almost the same result.
i tried to get a side view, it's really hard to determine depth from pics.
in the last pic you can see how deep into the tooth i am. it's really only about 1/2 way to the root, and this leaves just a very narrow edge at the top. it's operating on the top 50% of the tooth, i think i'd want to be deeper, no?
if this was my sedan i'd be fine with it. but this is a rig i intend to push up against stuff and force it over.
thinking i want to be hitting a little closer to root and have it push off b4 coming close to having pressure on the tooth top
Reactions: LieutenantJohnson
Looks good to me. Be cafeful going too deep. Here's mine,
I now have a bit of a howl from 50-60mph. I think yours is just about right.
thats more like what i'm thinking
yours looks more like what i'm thinking, if i had that nice cushion at the top like yours. it has released b4 coming close to the top edge. i like that better than mine.
this is my 1st and i really want it as perfect as i can get it.
This pattern is classic pinion too deep: you have a half moon and it's flat and straight across the bottom of the tooth.
Which is why I was warning him not to go too deep. Also explains why I have a bit of noise. Gonna have to address it at some point. I may toss the Traclok for a Truetrac.
Oh okay. How bad of a noise does it make?
Enough that I can hear it over all the other normal noises a TJ with a hard top makes. I can modulate the howl on load or coast, but it's most noisy under constant load, such as maintaining 55mph.
i hear you, i'm gonna make the slightest change i can. and can always come back to this set if it's not going to work
