IAC needs replacing?
@macleanflood @hear idle gremlins update. Got her back from the mechanic. had a smoke test done and all the electrics checked. did a throttle sensor re-calibration. Found a leak by the evap canister. picked her up and the idle was good. dropped below 700 a couple of times. But she drives great now. called them about the drop and they advised, if it goes batty again, its the ECU. what do you guys think? gonna check her out for the next few days and see what surprises, if any, come up. Cant wait to get to the point of driving without the fear of a stall.
my 2001 4.0 idles at like 500rpm when warm, if it idled at 700 warm I personally would be looking at my throttle mechanism to see if something is causing it to be open a hair, but 700 may be normal for you
Reactions: jayeljeep
Again...I'd check and make sure your intake bolts are properly torqued.
I'd check all your IAT wiring. Continuity and ohm checks back to the PCM connectors.
Most importantly I'd be logging live ODB data through the anomalous idle. Knowing what the computer is seeing and doing is important.
Just spit ballin here. If you’ve got a multimeter I’d look at the p0128 fault that you had awhile back. The multi meter can show you if the tps is flaky. If you really want a clear picture of the tps operation a Simpson 260 meter will paint a very clear picture.
A second thought is I wonder what your fuel pressure is? Do you run you tank mostly full or mostly empty?
Like @macleanflood suggested look harder for vacuum leaks.
Reactions: macleanflood
@TJ Jim. Thanks for the info. I run her always at least half tank or above. Im gonna try out the multimeter. Truly grateful for the advice. Much mahalos.
she fully stalled. Towing back to mech.
