Very nice!
Very nice!
Thanks! I like how it turned out, it's now got me debating on going taller / bigger tires or running as is for the seasonVery nice!
I think I'm already in it!Must avoid the cosmic bunny hole
Looks good.Relocated the locker pumps, thanks @taylormade73 for the inspiration on using the UCF bracket that was sitting in my garage.
Might want to flush out the drain hole in your upper bump tower. It looks a little clogged and that can rust out as well. New tires looks great!Been a little slow but have the front clear at 1.75" bumps on the OME shocks once I got the arms extended a bit. I'll be trimming down these 2" poly mounts I have. Also swapped out new Crown Bumpstops and cups. Mine were rusty.
True test will be if I can fit those rear tires in the wheelwell. Right now I had it bumped 2" so not real interested in extending past that. We'll see this weekend.
View attachment 159718View attachment 159719View attachment 159720
Do you know if there Is there a weldnut on the inside of that bump tower or is it just tapped/threadedMight want to flush out the drain hole in your upper bump tower. It looks a little clogged and that can rust out as well. New tires looks great!
I think it’s just tapped, you could always tap a new thread in it or go up a size if it’s spinning. I repainted the inside of mine when I flushed it out, that’s a way less fun repair if it rustsDo you know if there Is there a weldnut on the inside of that bump tower or is it just tapped/threaded
Reason I ask is the driver side bolt was spinning and was having a tough time getting the bolt out.
To answer your question, they're compacted with mud/dirt. Now that you mentioned it, I'll hit it with the pressure washer before installing the springs tomorrow!
Yea, both shock/coil towers got a full POR15 treatment over the past few days as part of this process, not thrilled with what I scraped out behind the Bumpstop tower but it's nothing I haven't seen before. After flush tower and hit it with some Rust-Oleum rust inhibitor.I think it’s just tapped, you could always tap a new thread in it or go up a size if it’s spinning. I repainted the inside of mine when I flushed it out, that’s a way less fun repair if it rusts
That’s what the filter is for!I think it’s time to clean your Jeep
Ha! KY water crossings keep the engine bay dirty. It could use a good wax too if your wonderingI think it’s time to clean your Jeep
