My experience: 3 stock radiators in 10 years and I finally decided to go aluminum with an electric fan. Higher capacity in fluid, more engine bay room, less rotating mass in that no fan or clutch. Again tons of experts on here and fine, I'll respect your opinion but you're wrong. It's called physics and although I'm not dynoing anything and trail use vs highway use are two different animals, there is parasitic power loss in the use of a fan clutch and fan vs electric. Heat transfer is better and combined with the added fluid capacity, electric fan and heat transfer my engine maintains a more stable temperature by leaps and bounds especially on the trail when you need it most going 6 miles in 4 hours. Engine runs smoother, power is smoother and quicker off the pedal but not by leaps and bounds. Power gain on my 4cyl, yes! how much, probably not more than a few but by percentage on a 4cyl, 37" tires, long arm suspension, G2 dana44 front and 8.8 rear axles 4.88 with ARB's. Ax15 and an Atlas 4sp...significant enough to notice especially going up inclines on the hwy etc. Around town and on the trail, insignificant outside of runs smoother, better pedal and cooling much more consistent.
