A good example of the internet amplifier is the Ford Triton V10 engine used in class c motorhomes and vans. Before I bought my motor home I did some internet searches because I knew nothing about that engine. I quickly came across warnings about a few early years where spark plugs blew out of the heads. The problem was described as a spark plug thread issue and was described as a common problem. I talked with a couple of people I knew that had the engine in the listed problem years and I called 2 different Ford service departments. One service rider said that he had heard about the issue but had not seen one in the shop. The other shop said he wasn’t sure but thought they did have at least one occurrence. My friends had never even heard about the issue. Ours is running strong. Im sure there was an issue but if you listened to the forums you would expect most to have the problem. I research things to death for this very reason.
