Kiwi TJ
I don't suffer from insanity I enjoy every minute
x2 Id be checking that alignment then work your way through things like tire pressure, brake calliper sticking, wheel bearings or even suspension wear.You mentioned you upgraded the steering. I'd double check the front end alignment.
Shaking in steering wheel usually means the tires need balancing,
Pulling to the right or left usually means you need an alignment done.
