Jeep TJ Sensitive Throttle
kstalker
Portland, OR
Hi All, I'm chasing down some high frequency vibrations on my stock 1999 Jeep TJ Sport 4.0 Auto, and am trying to sort out if my throttle sensitivity is normal. TPS reading at idle is 15.3%, and it revs up to 2,000+ RPMS with only about 1% throttle input, bringing it to around 16.3%ish. Is it normal to be this sensitive, or could this be an indicator of an issue causing the engine to surge with very minor throttle?
Engine idles well, but feels like it has a lot of vibration under load (even when stationary) between idle and 2,000 RPMS. O2 sensor seems to have a normal oscillation, and TPS sweeps smoothly up to around 75%
A TPS reading of 15.3% at idle is typically on the higher side for a TJ, which usually has a reading close to 0% at idle (that's what I found from searching). The fact that you're seeing such a small input causing a spike to 2,000+ RPMs could indicate that there might be an issue with the throttle position sensor itself or possibly with the throttle body.
Let us know what you find!
For reference...this might help...
-Mac
Interesting, my understanding is that an idle TPS reading of a % in the teens was normal, I'll keep digging. Appreciate the response.
-Mac
I've cleaned the IAC a couple times, doesn't seems to make a difference. It also hums along nicely at idle, just revs way up as soon as you nudge the throttle.
Reactions: macleanflood
Let me know what you find in regard to this number. Have you checked the FSM by chance? It seems like it should have something definitive in there.
Per the FSM:
"With the ignition key in the ON position, check the
TPS output voltage at the center terminal wire of the
connector. Check this at idle (throttle plate closed)
and at Wide Open Throttle (WOT). At idle, TPS output
voltage should be greater than .26 volts but less
than .95 volts."
So it looks like there is a range of acceptable values. I pulled mine from a scanner, but I'll try putting a voltimeter under the hood tonight.
Per the FSM:
than .95 volts."
Cool, let us know what numbers you get with the multimeter. That should be telling!
I have noticed with a standard ODBII reader and app such as Torque that the TPS readings are not accurate and range from somewhere in the 14-15% low end to 75% at wide open throttle. Obviously not correct.
When I scan with HP Tuners VCM Editor and chose the channels for the PCM I get accurate readings from 0-100% and the accurate IAC readings.
With that said I have seen the IAC hold open with the throttle position report 0.0% at 2200rpm before. In my case because of an error in my programming.
