Jeep Wrangler TJ Cooling System Overhaul FAQ
Are the fittings on the Mopar 5503 7653AB barbed? The Jeep I'm working on has a replacement radiator and the transmission lines are attached to barbed fittings.
It does have barbed fittings.
That’s what I have in my ‘06 because the original quick fittings had been cut off and A hose used to connected the metal line to the barbed fittings.
Reactions: Irun
This helps! I was looking at the picture, but it's hard to tell if it's a barbed fitting or not! (y)
Reactions: Dmn0805
The story behind my '06 not having quick connect fittings on the metal lines is due to the availability of a radiator with quick connect fittings needed in a short time period.
Original radiator cracked just before going on a trip in it. The only thing I could get was a barbed fitting version from Advance Auto Parts. I used what ever their store brand was. Cut the end of the lines off, used a small section of hose to connect the hose to the barb fittings on the radiator. I used that radiator for almost 3 years with no problems. A little over a year ago I rebuilt the entire cooking system and went ahead a used a MOPAR barbed fitting radiator rather that replacing both transmission lines. Put the Advanced Auto Parts radiator up in the workshop attic as a spare.
I was reading the whole thread, and for one moment, I thought that your jeep didn’t had barbed fittings.
Well, when it had the original radiator, it had the quick disconnects hoses/radiator fittings. Due to time constraints and part availability, I had to cut quick disconnects off the lines, at each a hose to them and install a barbed fittings radiator. When I did put a MOPAR radiator back in, I didn’t feel like replacing the lines so I just went with a MOPAR barbed fitting radiator.
Technically, it shouldn’t have barbed fittings.
I just did this a couple of weeks ago and with Mopar 5503 7653AB and I do not believe there were barbs. By barbs I mean a barb like on a fish hook. The connections were only bulbed/fatter on the ends, no sharp points.
Reactions: Irun
Hey fam, just did my replacement this weekend. When I ran the distill water to flush the system, the water started coming down near where the lower hose is connected to the water pump. I am guessing it the hose/connection as it has a rusted out worm gear ( could not get the constant clamps in original list to work on this big hoses). Will look into it tomorrow AM to determine the cause of the leak. I pray it’s not the water pump gasket just as the leakage was almost instantly.
Could it have been leaking from between the block and water pump where they're bolted together? If so, that's fairly indicative that the block's seating surface was not adequately cleaned of ALL of the old gasket before installing the new gasket and installing the bolts. Even a small shard of the old gasket will cause it to leak. The block seating surface has to be absolutely pristine. After scraping the old gasket off as much as possible, I follow that up with a thorough wire-brushing with a good light to help me see that it's absolutely free of all the old gasket and that it's 100% bright and shiny clean before installing the new gasket.
Just to add another personal experience with the water pump gasket. I am OCD when i comes to cleaning gasket surfaces so bear that in mind. This was first time on a Jeep but I have done in on a ton of other engines, gasket surfaces always need to be super clean. Short of removing metal there was no way I was going to get the block side of the water pump housing shiny clean. I used everything, acetone, let it sit, brake cleaner sprayed on rag and then wiped on, carb cleaner, scraped with razor blade. Some of the gasket was still on there after it felt pretty smooth and I just kept on and on. I finally had to give up. It felt really smooth, but was not shiny, and i put it back together. So far no leak. As above, a really good light is a big help. Note: I did not use wire brush as I was worried I might create grooves, etc but had not read on here that others did that with success or I would have for sure.
Reactions: Dmn0805
As always Thankyou Jerry for your insights. I always wonder how you figure it all out just by hearing the symptoms. You are absolutely correct the gasket was not seated correctly and had failed.
Than you Scott for your advice, I will definitely have to follow your OCD and do something about the cleaning part. I will update you all with the result of my 2nd attempt at cleaning it. Thank you again for all the inputs.
Reactions: Jerry Bransford
Should I replace my entire cooling system at once?
It's a wise thing to do, yes. Let's say you buy a used Jeep Wrangler TJ with 100k plus miles on it. Well, first and foremost you have to know that as I'm writing this in 2017, your vehicle is anywhere between 20 years old (if it was made in 1997) to 11 years old (if it was made in 2006). Either way, if you have no record of the cooling system having been replaced, then you're on your stock cooling system, and even if the miles are lower, that's still a lot of time for a cooling system. Plastic and rubber wear out over time, as do water pumps, thermostats, seals and coolant.
The number one thing that is likely to fail in stop-and-go traffic or long road trips is most likely your cooling system. Replacing the major components in your cooling system is a fairly inexpensive and easy process. Assuming you use OE replacement parts (which is always recommended for longevity), you can expect an easy 10+ years and 100k+ miles out of your new cooling system.
Stay away at all costs from cheap replacement parts from AutoZone, O'Reiley's, NAPA, and other auto part stores. The parts they sell are known to fail prematurely, and will not last nearly as long as OE Mopar replacement parts.
So yes, it's a very wise idea to replace all of your cooling system components at once. In fact, you'd be a fool not to!
What parts will I need?
I've compiled a list of part numbers for the radiator, thermostat and water pump for our Jeep Wrangler TJ vehicles. I figure this information will be very handy when doing a cooling system overhaul.
A few things to take note of here are that in the links above, I'm only linking to OE Mopar parts (as I believe any other cooling system part--especially ones from local auto part stores--are far inferior). The thermostats I'm linking to are Stant SuperStat thermostats with the factory 195 degree configuration. Stant SuperStats are very highly regarded as being better than OE thermostats for our vehicles.
4 Cylinder (SE) Models:
1997-2002 (2.5 liter 4 cylinder)
Waterpump: 4626054AF
Thermostat: 52028186AC
Thermostat Gasket
Radiator: 55037652AA (Manual Transmission)
Radiator: 55037653AB (Automatic Transmission)
Upper Radiator Hose: 52028266
Lower Radiator Hose: 52079670AA
Fan Clutch: 68065080AA
Replacement Radiator Cap: Stant #10234 (yes, this part is a must if you're refreshing your cooling system)
2003-2006 (2.4 liter 4 cylinder)
Waterpump: 4694307AF
Thermostat: 53010552AC
Thermostat Gasket
Upper Radiator Hose: 52080030AD
Lower Radiator Hose: 52080031AD
Fan Clutch: 68064765AA
6 Cylinder Models:
1997-1999 (4.0 liter 6 cylinder)
Waterpump: 68382489AA
Thermostat Gasket
Upper Radiator Hose: 52028264AB
2000-2006 (4.0 liter 6 cylinder)
Waterpump: 5012366AG
Thermostat Gasket
Radiator (2000-2004 only): 55037653AB (Automatic Transmission)
Radiator (2005-2006 only): 55037653AC (Automatic Transmission)
Should I go with a low temp thermostat?
No, do not buy into the hype that a low temperature thermostat is going to benefit you. There are very, very few cases where a low thermostat will be of any benefit. For 99% of us, they're going to make things worse since the engine will take longer to warm up which can have a handful of negative effects on the engine, performance, and potentially even fuel economy. Whoever started the whole "low temp thermostat" idea needs to be shot, seriously.
Your Jeep was designed by Jeep engineers to operate within a certain temperature range. Making it operate cooler than that designate temperature goes against everything that is programmed into the ECU. There's a reason engineers did the things that they did, and if you're dumb enough to try and reverse engineer it because you think you're smarter than they are, well, then perhaps you're on your way to a Darwin Award :p
Seriously though, all humor aside, don't use a low temp thermostat unless you have some sort of very, very special use case (which doesn't count as "I go rock crawling").
Why do some later model and aftermarket thermostats have either a very small bleeder hole, or no bleeder hole at all?
According to @mrblaine, the later Mopar thermostats and others of similar design have changed the bleeder hole to be nearly non functioning. We've noted the change in the self burping function many times and finally resorted to drilling a 1/8" diameter hole next to the jiggler which solved the problem and made them work as before. The later ones are not self burping in the least until you fix them.
So in other words, you can drill a 1/8" hole in your new thermostat if it has a hole that is much too small, or no hole at all. It's very easy to do and nothing to stress over.
There's a very good discussion on this subject in this thread.
What kind of coolant should I use?
In my opinion you should be using HOAT coolant in your Jeep Wrangler TJ. Hybrid Organic Acid Technology (HOAT) is a combination of IAT and OAT. Several manufacturers are using HOAT for their vehicles. One version is dyed orange and contains 10% recycled antifreeze. Another version is dyed yellow and does not contain any recycled antifreeze. Both of these HOAT antifreezes use the marketing designator of GO-5. They are compatible with each other but mixing them with IAT or OAT is not recommended. The normal HOAT antifreeze service life is 5 years or 150,000 miles (250,000 km).
A perfect example of a good HOAT coolant for use in your Jeep Wrangler TJ is the OE Mopar coolant or Zero G-05 coolant.
How much coolant should I use?
See this thread for fluid capacities (it varies depending on which model TJ you have): Jeep Wrangler TJ Fluid Capacities
Tap water or distilled water?
If you are flushing your cooling system or using a coolant that is not pre-diluted, DO NOT use anything other than distilled water. You can buy gallons of it at your local grocery store for less than 99 cents. Distilled water doesn't have the minerals in it that tap water does. If you fill or flush your cooling system with tap water, you will start to see rust build up (which turns brown in the coolant) that occurs sometimes in as soon as months. This will ultimately destroy your cooling system in short order, and make a big mess of things.
How do I replace the radiator?
See this thread: Jeep Wrangler TJ Radiator Replacement
How do I replace the water pump?
See this thread: Jeep Wrangler TJ Water Pump Replacement
How do I flush the cooling system?
See this thread: How to flush the cooling system on your Jeep Wrangler TJ
What kind of hose clamps should I use?
Contrary to popular belief, a "worm gear clamp" is not the way to go with cooling system hoses. What you want to do is re-use the stock "constant tension" clamps (which you can also find on Amazon in various different sizes). The stock "constant tension" clamps are far superior than a "worm gear clamp" because they apply constant tension as the name suggests. The problem with the worm gear clamps is that often times you'll get it tightened down too much, and it can cause a very small leak in one area of the hose where the clamp might not have enough pressure or have something under it causing it to not seal correctly.
I've seen a lot of cooling system hoses (especially radiator hoses) leak, and it was entirely due to the person using a worm gear clamp as oppose to the constant tension style. There's a reason the factory uses the constant tension clamps, and you should re-use them or source out new ones (if yours is missing them) if you're going through the process of overhauling your cooling system.
What would you recommend as far as heater core lines? I’ll be replacing all rubber hoses in my 4.0 as it now has 170K and I don’t know if they have ever been replaced
I would just go with whatever the auto part store has, just make sure you go to a place like NAPA who tends to carry higher quality parts than Autozone for example.
Reactions: Dmn0805
If you are planning ahead then I would order parts from Rockauto.com. The prices are often a fraction of the local stores even with shipping. There is little difference between a $10 Continental hose and a $16 Gates hose. They are both high quality replacements. You can really save on shipping if you get a few washer blades, oil and air filters at the same time. There are always coupons available online if you search for a few percent off.
Turned off the 03 Rubi today (170K) and heard antifreeze & bubbles bubbling into overflow reservoir. No overheating on dash gauge but have noticed trans temps (I installed trans gauge in pan) around 210* which usually run 140-160*. No water (milk) in oil. Just ordered Mopar coolant overhaul. What’s the You guys think my head gasket’s blown?
Turned off the 03 Rubi today (170K) and heard antifreeze & bubbles bubbling into overflow reservoir. No overheating on dash gauge but have noticed trans temps (I installed trans gauge in pan) around 210* which usually run 140-160*. No water (milk) in oil. Just ordered Mopar coolant overhaul. What’s the You guys think my head gasket’s blown? Or just a bad radiator cap? Best way to check?
Just wanted to say this guide is awesome!
I just did the cooling system overhaul. I used this to check for leaks when I put it all back together. You could check your system before you do anything else. Wish I could help diagnose more.
Doing my TJ coolant system overhaul now. Two thoughts/questions:
1. Years ago we would drill a small vent hole in the heater core top nipple placing it about 1/2” to 3/4” from end of nipple orifice. The idea is to fill coolant system with upper heater hose on but exposing vent hole. When all air is purged from system, slide hose all the way in and tighten clamp. This seals vent hole.
2. Will the ball valve shut off to the heater core cause issues as I’ve done it on my ‘74 CJ5 & it does reduce cabin air temp by closing off flow to heater box.
Reactions: Dmn0805
Hi all - I am replacing the entire coolant system in my 99 TJ. I have had a local shop tell me all of these Mopar parts are discontinued and the only option is aftermarket. They also said to be careful buying parts from Amazon as it may be a 15-year-old part that won't work correctly because it's been sitting in a box for so long.
So I guess my question is - would you still recommend purchasing the parts on the list at the top for my 99 TJ? Some of the prices for things like the radiator are not too far off some aftermarket options, like the Griffin radiator for example. Any additional thoughts?
