LED headlights lumens too high for on-road use?
Oh I understand. Unless you daily north of the 40th it is hard to justify the cost.
Am I missing that those particular lights have a heater so ice would not build up on them as happens with unheated LED headlights? I see no mention of them having a heater element for driving north of the 40th parallel.
Yes but it's still too frigging expensive for Wrangler headlights IMO.
You've got at least 20 things on your rig that a lot of folks would consider too expensive, as do I for some of them.
You priced out a 5.5" hub kit lately? This is without inner shafts so add another 450-500 for quality versions.
How about a Walker beadlock nowadays?
You would spend about 5 grand on those two items that you would need now and you still don't have tires. Fancy headlights are a mere pittance comparatively. Tires would put you over 7000 dollars. Tires, rims, hub kit, 7 thousand dollars. Now that's expensive.
Not sure if they do or don't but that big heat sink on the back of them isn't there because they are a cool running light.
Reactions: Blackjack
For presumably real optics, and nicer looking than the Phillips, I don't think it's expensive at all, especially since it's plug and play.
They aren't anymore expensive then a lot of other quality LEDs for sure. Give them a test and post some results. I like the OEM look with the LED function.
https://www.theretrofitsource.com/S...roBright-LED-Headlights-5.75-Round?quantity=1
It looks like they were engineered by mirimoto in the USA according to retrofit source which is very encouraging from a design and performance perspective IMO.
Mirimoto makes some of the best aftermarket LED lights IMO. I have considered them for my daily driver tundra and they are the only manufacturer I know of that still includes a height adjustment/ load leveling function on the aftermarket headlight. The set for a tundra is $1000 for some perspective which is why I don't have any yet.
I have been running the non heated Trucklites since the current version came out. I have only ran into a couple of times where I wish they were heated and one of those the entire Jeep iced over so headlights did not matter at that point.
Black lives in Alaska and runs the non-heated Trucklights. I live in the south and run the heated Trucklights…
The world is just out of balance.
And if the option was available at the time I purchased mine I would have probably got the heated. Even though I live next to the ocean the winters here are cold and dry for the most part.
Reactions: NashvilleTJ
I'll plug them in and let you know if the glass gets warm when they get here.
