I get this engine noise about once a month when starting the vehicle. Was able to capture the noise after restarting it.
Yea it stopped on its own.Can't tell because of the short length of the vid, but did the noise stop by itself after only a second or so?
Thanks for this input. I'm about due for an oil change so ill look into adding an additive before the change.If it was that loud and stopped like someone flipped a switch shortly after starting, seems like a collapsed lifter to me. It's probably worth trying one of those engine oil cleaners like marvel mystery oil or the like, but I wouldn't get my hopes up. After that, I'd pull the valve cover and check the tightness of the push rods. Does this happen just when it's cold?
Glad you mentioned this.You can also try a high mileage oil which has more detergents in it.
Used M1 HM in my YJ several yrs ago to clean one up.
First, disconnect serp, belt see if it stops if not Get engine stethoscope, I needed one to find bad lower rod bearings it saved my crank shaft for the re-build.Sounds like a leaky, sticking lifter.
I have a stethoscope but the noise only lasts about five seconds or less and only happens about once a month. I’ll definitely get my listening tool against it if the time/duration allows me to do so.First, disconnect serp, belt see if it stops if not Get engine stethoscope, I needed one to find bad lower rod bearings it saved my crank shaft for the re-build.
No cracks that I know of like I had on my 99. It doesn’t sound the same to me as a cracked manifold and it only lasts for about 5 seconds on start up (approximately once a month).I can't listen at work, but maybe one of the rear exhaust manifolds are loose, or you have a crack back there?
Awesome. I’ve had sea foam laying around for a while, so I’ll try that and then I’ll try motorkote if this doesn’t work.My jeep had the same noise after setting. I know it was an sticky lifter, Was so bad at times it would miss till it pumped up. Had most of a bottle of Motorkote and dumped in. And not a peck since. I'm not a fan of additive's but had bought it for something else.
Thanks for letting me know I can make my own decisions lol.A five second noise once a month, I don't know if I'd worry about that. I wouldn't but you do you.
You could search for the countless other threads on this exact issue with videos of the same noise or crack jokes, either works. You can make your own decisions.I was more worried about how bad this might be
I did multiple searches. Later, I made a thread since I was lucky to capture the noise. I then did many other things before eventually having the honor and privilege to poke fun at your nonsense.You could search for the countless other threads on this exact issue with videos of the same noise or crack jokes, either works. You can make your own decisions.
