Link
@Ptm
Thanks for this post! I did the same repair using the same boot. Only difference is I used Flex Seal rubber caulk which worked fantastic. The plastic “tower” where the console screw goes in was broken on mine so I plastic welded it up and drilled a new hole for the screw to go in. I have no idea how long it’ll last but it saved me $150+ on a new one. I’ll probably need a new boot later but for now, this is working perfectly.
Thanks for the idea!!
