I'm looking for temporary solutions to reducing vibrations of the 4" lift of my 1997 TJ. I believe it is a 4" rough country lift kit with probably 1" body lift and 3" suspension lift.
Would I be able to drop the transfer case more than an inch? I was imagining that the vibrations would reduce more than the 1" drop kit it currently has. I have dropped it to around 1.5" with a kit along with several washers to test and it went well but the vibrations stayed the same. I currently only have the drop kit's metal bars with no washers.
I have a tom woods oem-style front driveshaft and the stock rear, no SYE, and using stock/unadjustable control arms. I currently daily with the front driveshaft out and it runs smooth but I do want to use 4x4 without having to install it every time.
Let me know if you need more info,
Thank you in advance
