Maybe this applies to more JKs than TJs, but for crossover steering setups, what measurements matter in regards to the location where the drag link mounts to the knuckle? I know the distance between the mounting point and the steering inclination axis will affect the steering rate, but what about moving that mounting location inboard? That wouldn't affect Ackerman at all, right, that is only affected by the tie rod? The only issue I can imagine is if you moved the mount so far inboard that the linkages flip the wrong way when turning hard left.
