I'm in the process of replacing the timing set on my 05 TJ 4.0 and I cannot get the new crank sprocket on. It binds on the key and is impossible to slide on. I tried lightly tapping it and it just gets more jammed on the key. The set I ordered was a Cloyes 90385SA from rock auto. Has anyone else had this problem? I don't see any burrs on the inside of the sprocket that would cause this. I could probably tap it on with a large socket, but that seems like a really bad idea. I assume I need to be able to easily slide this sprocket in/out in order to get the chain and the cam sprocket on.
