Easiest way would be to pull the control out and intercept the dark green wire that comes out of the mode selection switch (C3) and goes to the blower speed switch (C1). This is a ground/negative wire, all the blower and mode controls are in the negative side. You can splice a switch into the dark green wire before it gets to the blower speed switch. If you ever plan to use the higher speeds though you will need a heavy duty switch or a relay, this is a 40 amp circuit.
(note, the attached diagram is the heat only option for a 2000 but if you have AC it makes no difference, it will still work)
