O2 sensor problem
aka5000
SWFL
2005 Wrangler TJ Rubi
I am getting the error code P0058 "Heater Control Circuit bank 2 sensor 2"
What I have done so far...
I replaced all four 02 sensors with NTK
I replaced the catalytic converter.
It worked well for about a week (2 maybe 3 small drives) then the CEL returned and its P0058 again.
I returned and replaced the bank 2 sensor 2 again.. still have the code after trying to clear it
I started pulling the wiring harness yesterday and didn't see any noticeable damage anywhere. My harness loom is shot and crumbling btw.
On a scan tool I can see its getting power with key on (1.27 for all o2 sensors) and while running a can see the graph change value for all except B2S2
Can I run my own harness to the o2 sensor from the PCM? The FSM says...
pin 33 on Black terminal is the signal
pin 10 on Neutral terminal is the Heater Control
The other two wires on the sensor should be grounds and I can ground to the frame, Correct?
What is the Pin 32 on Orange "O2 return, Downstream"
I also noticed I already have a remanufactured PCM. Came that way.
Did I miss something? Is there something else I need to be looking at?
Thank you in advance
Reactions: Wranglerfix
1.27v is too high for O2 sensors. They should typically range under .9v.
Are you sure you have new O2s?
@Wranglerfix could this be a sign of a bad PCM?
Isn't there a TSB about this?
I'm guessing your PCM is failing. Wranglerfix is your friend. It'll probably run awhile with the failing PCM but you'll have check engine lights and codes. Eventually it'll get worse and worse and if you let it go long enough it'll all shut down. I ran mine for over a year with the O2 sensor heater circuit codes. Finally started getting lots more random codes and running issues so I knew it was time for a new PCM. Wranglerfix got me running code free again. Mine is a 2005 too.
https://wranglerfix.com/
@aka5000 It is the pcm that has failed you. Faulty 02 sensors, hard 1-2 shift in the morning, rough idle and poor gas mileage are the other issues.
You can call me to discuss some further detail if you would like.
Thanks,
Mark
I have a 2005 Wrangler TJ Rubi that I just got as well haha! Same issue... let me know if this fixes please as I plan on replacing all 4 sensors this weekend first and if that doesn't work I'll most likely buy replacement as well. Thanks!
Reactions: macleanflood
Thanks,
Mark
A huge thank you to Wranglerfix. I called and spoke to him Wednesday morning and had the new PCM by Thursday night. Nice work guys!
It took maybe 2 minutes to change out the PCM and on first fire... No CEL
Thanks,
Mark
Hey Mark, Ive seen your Name Wranglerfix pop up all over this forum, I purchased a 2005 TJ 4.0 when arrived it had 2 codes P0135 P0155, both o2 heater performance codes at the same time didnt seem right, my launch scan tool shows me true Data i screen shot it while running from a ice cold start to operating temp, i wanted to share with you the data numbers but i just learned i wasnt able to upload photos on this forum, is there a Email you can share, so i can get your Professional opinion on this issue, in the email i will share with you the photos i found a little concerning as well, Thanks Mark I really appreicate your Help.
Michael P
Michael P
Congrats. You will be getting a new PCM soon. Recommend WranglerFix. Choose wisely!
  • USA Proud
Thanks,
Mark
Mark is the man. New to me 05 TJ Rubicon. Replaced O2 sensors, spark plugs and coil packs. Had the shift issue also. Purchased a new PCM from Wrangler Fix and BAM, a new jeep. Runs great, no lights and happy as heck! Thanks Mark !!
