190k oil change time last night. What I thought was a lifter tick is a noisy camshaft synchronizer. Upper bushing is pretty sloppy, so a new Standard Ignition unit is on order.
Always a sad occasion. I caved in myself last weekend.Put it off for as long as I could. Hard top went on today.
Welcome back to the dark sidePut it off for as long as I could. Hard top went on today.
The drive to work this morning reminded me why I waited. While it is quieter, it also comes with it's own set of noises. Oh well, that's what my stereo is for.Welcome back to the dark side
If you decide to sell ask a crazy number first. I thought $1,500 was a crazy number when I posted mine and I sold it within 20 minutes with multiple inquires at the asking price.This is the reason why I haven't put my hardtop back on since I removed it for summer 2020 I was perfectly OK with soft top last winter .. last year I ran with the half doors/sliders, this year I think I will put back just the full doors. Will have to think about selling that hard top if I am not going to use it.
I have some Noico waiting to be installed inside my full doors. Probably my first project when I get to Corvallis.This is the reason why I haven't put my hardtop back on since I removed it for summer 2020 I was perfectly OK with soft top last winter .. last year I ran with the half doors/sliders, this year I think I will put back just the full doors. Will have to think about selling that hard top if I am not going to use it.
Doors only? I’ll be interested in hearing your report. I have 18sq ft, but haven’t installed it. Locations I was thinking are transmission tunnel and firewall.I have some Noico waiting to be installed inside my full doors. Probably my first project when I get to Corvallis.
Yes, just the doors this time. I did the transmission tunnel and the high spots under the front seats last year. I've read a couple of posts by Blaine which said doing the doors made a significant improvement.Doors only? I’ll be interested in hearing your report. I have 18sq ft, but haven’t installed it. Locations I was thinking are transmission tunnel and firewall.
Interesting. I will heed that message from MrBlaine. Thanks for thatYes, just the doors this time. I did the transmission tunnel and the high spots under the front seats last year. I've read a couple of posts by Blaine which said doing the doors made a significant improvement.
Thats great to know because I have one sheet of noico left over from deadening the tub and I plan to use it on the doors* Do you know where blaine said that(looking for pics)Yes, just the doors this time. I did the transmission tunnel and the high spots under the front seats last year. I've read a couple of posts by Blaine which said doing the doors made a significant improvement.
Per your last part: I think it would have to depend on how much throttle youre giving it. I would think that the axle raises more in 1st gear than 5th on the freeway since you have way more tourque than 5th gear, thus letting the antisquat reach its highest number correct? If I punch it in first from take off, my front driver tire wants to lift to the moon, if I punch it in 4th or 5th, my front end doesnt really move at all (or so I can feel) -I could be totally wrong but just thinking out loud hereReplaced the noisy camshaft synchronizer. Now I need to replace my rear brakes. Pads are getting thin. Always something!
And with the hardtop on, I get to continue with my vibes drama. The hardtop just acts like a tuning fork, enhancing the harmonics that I hear. Considering taking it to an upholstery shop, have sound deadening installed and then some salt/pepper marine grade carpet glued on to see if that helps some.
I experimented a little and put my angle finder on the rear diff, engaged the parking brake and tried to simulate the axle up movement under load in 1st gear while my co-worker watched the angle finder. Up travel was less than 2*. It was a concern, as I have the much hated MC arms back there, so I wanted to test that theory. Do you think by doing that test I'm putting enough load on the axle to simulate the load it sees on the freeway at 65mph?
Makes sense to me. I was reefing on it pretty good and had the park brake on as tight as I could, then feathered the throttle to get some load.Per your last part: I think it would have to depend on how much throttle youre giving it. I would think that the axle raises more in 1st gear than 5th on the freeway since you have way more tourque than 5th gear, thus letting the antisquat reach its highest number correct? If I punch it in first from take off, my front driver tire wants to lift to the moon, if I punch it in 4th or 5th, my front end doesnt really move at all (or so I can feel) -I could be totally wrong but just thinking out loud here
Sounds like you need a v8 swap to fix your issue.If I punch it in first from take off, my front driver tire wants to lift to the moon, if I punch it in 4th or 5th, my front end doesnt really move at all (or so I can feel)
If you want to be patient...My jeep is about to hibernate. I can send you my uppers to try, with johnny joints, to see if it makes a difference.Replaced the noisy camshaft synchronizer. Now I need to replace my rear brakes. Pads are getting thin. Always something!
