Wordplay
is there any actual help contained in this wordplay?
Like a ghost!
Either I am an idiot or something isn't showing up cause I am lost
Falken Wildpeak AT3W, currently at 20psi, gonna try higher
The pear joke just went completely over my head so you’re gonna have to elaborate![]()
We just don’t want people going around looking like big pieces of fruit-
It is certainly guess work trying to do this on a forum but if you’ll be persistent you can get it to ride pretty good. 20 psi should be pretty smooth, actually lower than a lot of guys run. 26 -28 may make it less bouncy- hard to say. 20 would be lower than I would run on the road myself.
Load Range C is my favorite load range.
Read the original and then the quoted version. You'll find it. And then there is quite a bit to unpack.
It's all just relative, steering is whatever you feel like it ought to be.
OP: just look at the subtle difference in the two posts. It might be invisible, but not quite.
All that was said was FIFY? I am not sure what that even means...
Which two posts are you referring to?
So wait you switched a Currie track bar for a rough country track bar?It came recommended from Dave Kishpaugh at Jeep West in Oregon, great dude. It is a Rough Country (best clearance) track bar with larger bushings pressed in, larger 9/16ths holes and bolts on both the bracket and axle ends. The factory one mounts in the same position, just rotated 90 degrees. We are talking a possible 1/8-1/4" this is lowered now. Also this harshness was present with a factory style mounting Currie Bar
The Currie track bar is far more superior than rough country’s.
The only thing rough country I’ll get is their motor mount spacer lift.
Switch back to Currie to correct your steering geometry.
The currie had massive clearance issues and smashed into the front diff cover due to the huge Johnny joint
