I don’t remember exactly how my h they measured once they unbolted and extended them. I think it was around 24 inch or 25 if I remember correctlyIf you unbolt the bottom shock mount how far will the shock extend?
Maybe you should try to unbolt them and do what I did. The impact before I did this, they felt super bouncy, even just pulling out the driveway. It wouldn’t absorb the impact thus causing them to feel bumpy.Ever since I installed my rancho 5000x I found the rear ones over bumps are jarring. Always wondered if the shock was faulty but it seems like the rear end doesn’t absorb impact but instead just bounces of them..
It's amazing to think that people are able to free up a shock by hand better than a 2 ton vehicle moving around is able to do.
If you try to push it in with your whole body weight, you are not even coming close to the dynamic force of one corner of your rig when a tire hits a bump. That can be 1000's of pounds of force.What you trying to say here? I’m of the same belief.
Doesn’t make sense to me either but it worked.It's amazing to think that people are able to free up a shock by hand better than a 2 ton vehicle moving around is able to do.
The only way cycling the shocks would help is if they are hydrolocked. And cycling them very slowly causes the fluid and gas to go back to their correct chambers or locations. On some older gas shocks the instructions would even mention it,but I haven't seen that for a long time.
Black Max's are gaining in popularity around here. I have never ran a set and as far as I know they do not offer a 10-11" travel shock.Any other recommendations?
Update: 2 years or so later. It seems like they wore out my tires unevenly. Maybe the shocks were still defective after all. Haven’t even put 8k miles in these tires. I was told I need to buy 3 tires soon. Such a shame since they were relatively new tires (goodrich Ko2).
I enjoyed the smooth ride the ranchos rs5000x offered but I’m thinking of biting the bullet and finishing everything I thought about buying suspension wise. The shocks were the first thing I purchased along with the tires. Had the tj to ZJ tie rod conversion done that year. This last summer I had metal cloak control arms installed, driveshafts, Currie coil springs. Had an alignment done every time something was messed with that could mess it up.
it leads me to believe it’s the shocks that are/have gone bad. Only 1 out of the 4 tires is still good. To use.
Thinking of biting the bullet and buying the anti rock sway bar by Currie, better tie rod/drag link, and a whole new set of shocks that aren’t ranchos.
