The 4.88 gives slightly over 2700 in 5th gear at 70 mph. Guess I am used to different engines. Have had two JK's that run 1700-1800 at highway speed in OD.
Be very cautious with the tire size you plug in. The calculator works on the exact tire radius when measured from the center to the ground or the rolling radius. If you plug in a 35" tire, that is typically not the rolling radius doubled. For 35's, I typically plug 34".The 4.88 gives slightly over 2700 in 5th gear at 70 mph. Guess I am used to different engines. Have had two JK's that run 1700-1800 at highway speed in OD.
You should really knock that some of that off. Some of us giving the advice have rigs we haul on trailers to do the extreme offroad stuff and that trailer and rig happen to be parked beside a bone stock 2004 TJ Unlimited, an 04 TJ on 33's with 3" of lift on 33's with the 42RLE and 4.88's, an 01 TJ on 35's with an AW-4 out of an XJ and 5:38's, and a bone stock XJ with the AW-4 and 3.73's.Lots of the advice on these forums comes from guys who do the extreme off road stuff. Some of those guys also trailer that Jeep. But some of us actually only own a Wrangler which we use everyday for everything. When seeking advice be sure to research the source too.
LIke I and others have said, you should have personal experience with the 42RLE before continuing to give your improper advice and opinions on gearing for the 42RLE which you have no personal experience with. And my TJ with its 42RLE has never been trailered, it's driven everywhere I take it.Proper Gear Choice for a DD should drop your rpm in OD far below the peak torque/horsepower. OD should be used to drop rpm, quiet the ride, extend the engine life, reduce wear. All modern cars do that. The Audi 8speed transmission hits top speed in 5th gear because the extra 3 gears drop rpm for all those reasons AND to deliver better gas mileage. Same with Jeeps little Renegade with the 9speed. I think it hits top speed in 6th gear.
Off road, Trail dedicated sure build it to stay in that peak 2700rpm range but for a daily driver gear it to cruise closer to 2000rpm. And drop a gear or two when you need more power. Driving my TJR with 33s, Yellowknife to Denver, 2200miles, I was cruising on the Interstates all day at 75mph, 2700rpm... horrible.. 15mpg. Made me want my old YJ with the 3.07s which did the same trip in 4th gear at 2300rpm... 22mpg. 100gallons of gas vs 150gallons of gas.
I know it has been said over and over but until you've driven one close to or right at stock, it's hard to understand the 1000 rpm drop down to 2000 rpm at 70 and the crap trans that won't downshift, and in OD, if the road even remotely hints that it is going uphill, the rig won't pull it and you keep giving it more gas, it won't shift, more gas, won't shift, and then when it does, it goes into 2nd instead of drive and your RPMs are through the roof.LIke I and others have said, you should have personal experience with the 42RLE before continuing to give your improper advice and opinions on gearing for the 42RLE which you have no personal experience with. And my TJ with its 42RLE has never been trailered, it's driven everywhere I take it.
Your guesses on the proper ratios for the 42RLE are just that, guesses. Incorrect and baseless inexperienced guesses to be more precise. With more experience you would have already realized that proper ratio choices for the AX-15, AX-5, 32RH, NV3550, NSG370, etc. don't work where the 42RLE is concerned.
Agreed !!I *heart* my 6 speed manual!
What ratio did you switch to?Changing the gears on my 42RLE with 33" was one of the best things I ever did to my wrangler!
Sent from my SAMSUNG-SM-G891A using Tapatalk
I'd consider 5.13 perfect for the street and highway for that combination. Of course it'd be superb for offroad too.33s, 4spd auto... 4.88 is perfect, that OD is so steep it is like the stock Rubi 6speed with 4.10s.
6 speed is 2950 in Drive at 70, auto is 3500 at 70.33s, 4spd auto... 4.88 is perfect, that OD is so steep it is like the stock Rubi 6speed with 4.10s.
Auto is 3500? What transmission or tire/ratio combination were you thinking of Blaine?6 speed is 2950 in Drive at 70, auto is 3500 at 70.
OD is the same and you are correct, it is terrible.
How do you like the performance on the highway?4.88
