Do you trust what you know? Can you look at something done a certain way and derive anything useful from how it is done?
Or, do you just throw lots of metal at it and solve the problem that way?
Hypothetical case in point-
Transmission cross member to hold up a 32RH at the end of a 4.0 with a NV241OR hanging off the other end.
What size would you make the cross member?
What size would you make the bushings if you use them at the frame?
Would you try to reuse the OEM trans mount?
What thickness would you make the tabs for the frame side connections?
What diameter and grade bolt through those tabs?
Bonus question- can you make the 97-02 transmission adapter mount low profile, if so, by how much?
3/16" material if you can bend it, or some 1.25" and 1.50" , 1/8" wall tubes.
i used rubber leaf spring bushings pushed into a piece of tube, if they can handle that job they can handle this 1.
i did reuse the trans mount after i cut 5/8" out of it (04).
tabs at the frame were 1/4".
i think i used a 9/16 bolts because they were on hand but 1/2" is sufficient , grade 8 .
i made 2 versions, 1st was a beefy chunk of 3" I beam cut down the web and contoured around the exhaust and TC output. it worked but i was not happy with it for some reason. even though i coulda dropped the jeep on it and not bent it, it was a bit much.
the next was a slip tube version like many outfits sell. it worked fine but i didn't like the skid i'd made (3/16" steel and heavy). rather than try and guess what pre-made skid might fit around it......i pulled it all off and just got a Savvy.
can you make a 97-02 mount LP? if there is room between the skid and TC, i'd think you could find a way.
they only reason i bothered with any of it was to have the support independent of the skid. i have so much to do, removing the skid and supporting the drive line every time, and always having that support in the way, was just a PITA.
also i have seen mention that mounting directly to a cross member is a bit rigid for the drive line, your turning a 3 point support sys into a 4 point, and moving the vibration dampener from directly under the drive line to out at the frame.
i got most of this typed while y'all were still goin, and may be redundant to the issue.
