So..just about done with front half of lift install (2002 Tj Sport, 2 ½" lift, Bilstein shocks). I will post sep thread on that, had to make some concessions to budget but, another story. I bolted it all back together and checked toe. First time, I used 36" of ¼ steel tube and marked at 32", clamped to break rotor and got 56 11/16". Then did rear and got 57 ⅞". So that resulted in a total toe "in" of 1 3/16". Almost fell over. Said "no friggin way, I must have done it wrong". Also took for ride and the thing handles like crap. Vague, crappy steering, etc. But I thought that was trackbar, etc. Did it a couple times, same result. So then I tried other method mentioned here. Use wood screw in tire tread and rotate 180 degreees for rear vs front. This time, front was 64 ⅞" and rear was 66". So again, a total toe of 1 ⅛"! This actually gave me some comfort as it means I wasnt totally out to lunch on the first try. I bought the Jeep with a blow motor so I dont know how it drove before. I did take for test run after the motor install and it drove like crap then too. Question is, does this make sense to you guys? I am about to start setting up to correct the toe and wanted an idiot check before hand. Could it really be off by over an inch?? Again, you guys are the best. This forum is a treasure chest of great info and experiences. Thank you all!!!
