Dino could I get the file as well so I could upload it to my radio? I already have the cable and program needed.I will convert it into an Excel file for you.
Thanks for doing this.
I’ll share my config from chirp. It’ll not include everything Dino has but it’ll have the base things.I have Chirp on my laptop for my Baofeng. Are you indicating that you don’t have a file compatible with chirp?
I will convert it into an Excel file for you.Is the file for the other format a flat file that I can view on my computer?
I just need an e-mail address.Dino could I get the file as well so I could upload it to my radio? I already have the cable and program needed.
I'll make a Chirp compatible uv-5r export from the excel sheet for anyone that wants it.I will convert it into an Excel file for you.
RT Systems or Chirp?Dino could I get the file as well so I could upload it to my radio? I already have the cable and program needed.
Thank you Dino, I will definitely take you up on your offer, we will be arriving on the 23rd early afternoon.As posted in other threads, I will be programming the Baofeng or Rugged radios you guys bought for this trip starting Friday (23rd) afternoon. Here is how that will work...
I rented a house in town and you can come by any evening to have your radios programmed. Call first so we can make sure we are home! I will try to accommodate your schedules and will keep my computer with me whenever we are in town. This includes any meet-ups, dinners, the party at Grandpa's Garage (TBD), etc. However, I will NOT be programming radios at the trail head before a run! You'll be punching in your own frequencies at the trail head!
Casa De LJ
3463 Tierra del Sol Dr
Moab, UT 84532
562-665-6286
Save the address as Jackie and I will be hosting a party at our place at least one night during the week; also to be determined so as to not interfere with any official TJ Fest gatherings. Its BYOB but we'll have snacks, pizza, and other food.)
If you need a radio, go to Amazon and buy this... Baofeng UV-5R or equivalent. I'll be able to program the following radios... (UV-5, UV-5R, UV-5RPlus, UV-5R+, UV-5RA, UV-5RC, UV-5RE, UV-5RV2+. UV-5RTP, UV-5RI6+, UV-5RCx (2M/220MHz), UV-5X, UV-5Rx3, UV-5R III and the UV-5R3)
Or you can go to RuggedRadios.com and buy half the radio at double the price...but they work good. V2 or V3 is fine!
If your radio isn't listed above or I don't already have the software, and IF I have the cable that fits, I can download the software for your radio and it will cost you $25.00. You will keep the software since you paid for it and a cable will be mailed to you so you can reprogram your radio when you get home after the trip. But at least we will be able to hook you up for this trip.
There will be 120+ frequencies programmed into your radio. Your name will also be programmed in which appears every time you turn it on. You'll get...
All "TJ FEST" team frequencies
All 22 FRS Channels
All 30 GMRS Channels including repeaters
All 5 MURS VHF Channels
All 7 National Weather Channels
All KOH frequencies
All 45ish Rugged Radios pre-programmed race frequencies including Baja
3 - Moab ham radio repeaters (but transmit has been disabled unless you have a ham radio license)
Any questions?
You can get a good look at Savvy's Mid-Arm under my Jeep. Blaine did all the work and used it to prototype Savvy's Mid-Arm kit. I took Blaine's advice and outboarded the rear shocks, taller front towers, Fox shocks, Anti-Rock front and rear, his 15" brake kit and PSC hydro assist. Lots of other Savvy parts under there too.We are staying in the same neighborhood,
3415 South Village Loop
I don't need radios programmed, but I may be seen wandering around the neighborhood with a beer in my hand looking at other peoples jeeps. Don't shoot if you see a beer coozie and two legs sticking out from under your jeep, that is just me checking out the linkage.
Its OK as long as you repair or improve something while you're under there!We are staying in the same neighborhood,
Does reducing weight count?Its OK as long as you repair or improve something while you're under there!
Hi rasband, if possible please email a copy of our chirp file for the event when convenient @ [email protected]. thanks and can't wait to meet&jeep with everyone.I'll make a Chirp compatible uv-5r export from the excel sheet for anyone that wants it.
Great, thanksHere’s the info I shared:
https://wranglertjforum.com/threads/tj-fest-2021-moab-april-24-–-may-1-2021.34132/page-139#post-854129
I have a cable and Chirp as well but my Baofeng is an BF-F8HP. If you have a file that will work flat or otherwise, I would appreciate it. [email protected] ThanksHi rasband, if possible please email a copy of our chirp file for the event when convenient @ [email protected]. thanks and can't wait to meet&jeep with everyone.
If you follow this it shouldn’t matter what radio you have. The key is to import first and then copy the channels from my file that you open in chirp to that import before you upload!I have a cable and Chirp as well but my Baofeng is an BF-F8HP. If you have a file that will work flat or otherwise, I would appreciate it. [email protected] Thanks
