No it does not.
Then that right there tells you there's bind at ride height. I would adjust that arm for the bolt to slide in (at ride height) and try flexing it again.
No it does not.
We set the axle at ride height. We center the axle at ride height. We check uptravel at full stuff to fix any interference issues. After that, it has to do what it has to do and you won't change much of that.When I tacked everything in place yesterday, it was at ride height. When I tacked in the second UCA mount, I adjusted the UCA to the exact length of the first one, then tacked in.
Ya ever start overthinking everything, then get lost?.So what happened between tacking it in and now? If it was set with no bind then but has bind now, something had to have moved, right?
Center horizontally would just make the track bar really short, exacerbating the inherent bind due to a reduced arc.Silly question, why not have track bar connect at center of axle?
To minimize bind you want it as long and as level as possible.
Yea the TJ links are too short to 4-link. Need to get the arms longer for it to work, such as a midarm setup. I would go that way, but is short.I know for my JT one of the best lifts I've seen pulls the upper links into a fully triangulated setup (UCA mounts on top of diff), and eliminates the TB altogether. Is the TJ too short a wheelbase and rear UCAs to move them into the center more, and eliminate the TB?
So I am going to post an update on my progress, going to be long. I decided to raise the track bar the same amount it was over the original mounts, 2 3/4".
Made some extensions to go on top of old track bar bracket.
Raised mount -
Of course many of you already know what is going to happen. At near full bump, the track bar this the gas tank mount/frame brace.
Well, do not know if you try right? So the bar needs to move forward, hmmmm
Lets flip it to the other side and see what happens.....
Got to full bump with a little more than an inch to spare. Lots more room to pass by the frame. I think this might work.
Clearances are looking good on the drivers side. I reinstalled the passenger UCAM, and set everything up, pinion angle, centering axle. Up and down movement was good from bump to full extension. And flex is good side to side, did not break any mounts off flexing. I think I am getting there.
So time to reconstruct the track bar mount. I cut the back part off, and added a forward mount on top of UCAM.
Would a Watts link work on a TJ? Seems like it would be a perfect solution but I'm still new to all this
How high are the UCA and TB mounts above the axle?
