Now I kinda wanna figure out how large it would have to be.Packaging. The center hub of a Watts would need to be pretty large to accommodate the typical TJ suspension travels.
Depends on how much travel you want out of the rear suspension. The shorter the distance from each end to the center pivot, the less travel it will have.Now I kinda wanna figure out how large it would have to be.
Full traction does one for the JK. Takes a fare amount of real estate.Now I kinda wanna figure out how large it would have to be.
He says 8" of wheel travel. That is only factory travel on a JK. And that setup would only work with factory control arm mounts or a 3 link.Full traction does one for the JK. Takes a fare amount of real estate.
I forgot about that. In their literature they say they use it on their 6 inch lift with 12 inch travel shocks.He says 8" of wheel travel. That is only factory travel on a JK. And that setup would only work with factory control arm mounts or a 3 link.
This is not full bump. Those currie bumps will compress. Make sure you understand this incase things are very cramped or at their limits.Got to full bump with a little more than an inch to spare. Lots more room to pass by the frame. I think this might work.
Agreed. There is another inch to go.This is not full bump. Those currie bumps will compress. Make sure you understand this incase things are very cramped or at their limits.
Well, whether it solves the problem or not, that is some awesome puzzle-fab you pulled off on those brackets. Nice work.So I am going to post an update on my progress, going to be long. I decided to raise the track bar the same amount it was over the original mounts, 2".
Made some extensions to go on top of old track bar bracket.
Raised mount -
Of course many of you already know what is going to happen. At near full bump, the track bar this the gas tank mount/frame brace.
Well, do not know if you try right? So the bar needs to move forward, hmmmm
Lets flip it to the other side and see what happens.....
Clearances are looking good on the drivers side. I reinstalled the passenger UCAM, and set everything up, pinion angle, centering axle. Up and down movement was good from bump to full extension. And flex is good side to side, did not break any mounts off flexing. I think I am getting there.
So time to reconstruct the track bar mount. I cut the back part off, and added a forward mount on top of UCAM.
have some bind when cycling by hand
Shall we call it Currie bump? Full bump +1? This has been calculated in, just figured I did not need to mention it.
Awesome work!So I am going to post an update on my progress, going to be long. I decided to raise the track bar the same amount it was over the original mounts, 2".
Raised mount -
You haven't really changed the geometry much within the limits of normal street travel. more of fine-tuning the details. The kinda thing that when compiled together with 10 other fine tunings can make a huge difference. Still, great work.Just an update on this, I did know much about suspension geometry going into this, and this was an exercise and experimentation. Overall, after putting about 100 miles on, I notice no difference in how the Jeep handles or performs on the street. Kind of frustrated and disappointed.
Finished product below.
