Replacement HVAC wiring harness?
burdetter16
Tyler, TX
My A/C went out recently so I pulled the control module out today and found this melted wiring harness. I’ve looked every where and cannot seem to find a replacement one.
This one looks similar but it says it doesn’t fit a tj: https://www.amazon.com/dp/B0049TTR6G/ref=cm_sw_r_cp_api_glc_fabc_Cwx0Fb3FENXZ6
Does anyone know where I can get this part? It’s from the far right side of the module behind the selector switch
Reactions: Reign Mack
This one looks similar but it says it doesn’t fit a tj: https://www.amazon.com/dp/B0049TTR6G/?tag=wranglerorg-20
This is the name of the connector you need.
Reactions: CreepinDeth
Skip the connector and crimp on some female spade terminals.pic isn't perfect but I have replaced the vast majority of my hvac wiring. If I remember correctly, those particular terminals require a .187" female spade. $4 for a box of 7 from the auto parts store
  • USA Proud
Thank you
That’s a great idea! I was thinking I’d probably have to do something like that good to know it works!
Thank you
The female spades work great. Just get the right size. I used a 16-14 gauge (Blue insulated) with a .187 female spade. Autozone and Advance Auto both stock them. Also, use a good quality crimper and just make sure you get them back on the right terminal.
I covered the middle one with heat shrink so there was no chance they could short to each other but once they are connected, there is almost no chance of that happening.
I really didn't like the design of the replacement connector. I think the female spades are a better choice. Plus, it is much cheaper.
@reigthe wiring is severely undersized and the high current is routed through the switch. Once the wires age, resistance increases and the unfortunate byproduct is heat - a lot of heat. The current draw of the fan requires a larger fuse, so the weak link fails.
Think of an incandescent light bulb. The filament is burning (albeit in a vacuum) but the breaker doesn't trip every time you turn the light on. That's pretty much what is happening here.
Note that the switch and speed control resistor are on the negative side of the circuit. The positive side is very simple, fuse to ignition switched relay to fan motor.
@Reign Mack I started with the premise that the higher than normal current I was seeing was a problem with the blower motor. Replacing the blower motor w a new OEM one did not measurably reduce the current. I then built the low current circuit and relay array and also replaced the high current relay on the 12v+ side. Still had issues with the high current and excessive heat. Fortunately, it was limited to the high current side of the circuit so the control panel was safe. After a bunch of troubleshooting, I found the final wires leading to the blower motor itself to be severely corroded. I finally replaced the wires that went to the blower motor and now it works perfectly.
@TrueTexas thanks for the info, my fix was a bit vanilla compared to that, I didn't know what the issue was at first so went through the motions of changing everything starting with the cheapest item, blower control -> heater resister -> motor -> control panel. That's when I realised the plug was melted and plastic welded to the old control panel.
I did not reuse the blower motor connector. I used new fully insulated spade terminals and put some dielectric grease around them to keep them sealed. I think I posted a picture somewhere on the forum
Alright, I'll look for it. Thank you. This thread saved me a bunch of headache and money.. I got the dash partial tore out though
Reactions: TrueTexas
New to forum. I’ve had same issue and repaired using female spade connectors about three years ago. Recently I lost lower speeds on blower except for high. Replaced resistor, didn’t work, then replaced speed control still not working. Any thoughts?
Fist guess would be the switch itself. Pull it, see if you can get voltage from all the settings.
Discovered the culprit.
Discovered the culprit the plug to the speed control resister had loose connection. I was backtracking, left the ignition on with hvac switch in on position with fan speed set to lowest fan speed, as soon as I touched the plug it made a good connection and worked on all fan speeds. Now to try and find a replacement.
Reactions: Reign Mack and hear
I know I'm a little late to the party guys, but just wanted to say thanks for this great information. Saved me. Had this very problem the last wk or so.. & thanks to you guys I was able to repair. Thanks a bunch!
