In the process of installing my lift kit I notice the higher the Body and Frame of the vehicle goes the further back the spring seats on the axle are compared to the upper spring seats....
It seems the spring would be riding in a slight bend the whole time you're driving it... And would decrease your articulation during off-road maneuvers... Shouldn't a longer lower control arm and possibly a longer upper control arm be in the mix. Does any aftermarket Solutions cure this or am I overthinking the situation... it just seems a longer control arm the higher you go would be needed and would reset everything to the original plane of travel
Thoughts?
Thoughts?
